Hi all
New member from wales in Uk.
I have a mk2 91 2.5 (4d56) Pajero Swb manual. It’s a v24 chassis.
It won’t start without cold start spray or similar down a pipe.
Started one day a few months back.
Got in one morning and just turned over with no start.
Since then ,,DONE EVERYTHING I can think of ,.I mean everything. When it does eventually start, for first 5 mins it’s puffs out “loads” of light grey smoke and does not rev at all. !!
Then it’s fine.
Even my mechanic is struggling.
Please please help
Hi I presume that you had no problems prior to winter ? starting. Test pre ignition heaters might have faulty units. You will need a tester to test both voltage and current. Is pre heat light lighting on panel.
