Pajero sports 3.2 D 2012
Hi gents,
New to the forum and new to mitsubishis.
I have bought a Pajero sports 3.2 diesel with 185 000 kms on and would like to find out any good or bad info on them,as well as to what to look for in regards to maitenance in future.
Any help will be appreciated.
thanks and glad to be here .
cheers
Re: Pajero sports 3.2 D 2012
Welcome my friend.
Check 4WD system,if it is working properly,drive at least 60-70km on 4H and AHLc to see if there will be an "error".
Check EGR if it needs to be cleaned,intake manifold also. Install a Provent catchCan.
Check the Timing Chain Guide.
Do Valve alignment if necessary.
Change differential fluids,and if there is the opportunity,clean the DieselTank.
Στάλθηκε από το SM-N960F μου χρησιμοποιώντας Tapatalk
Thank you,
I will follow your recomendations.
How reliable are the 4 M41 engines?
thanks
