P0107 - MAP Sensor error
ben.koch
Country: South Africa
Vehicle: 2004 pajero swb
Re: P0107 - MAP Sensor error
Tue Jan 05, 2021 1:01 pm
Hi Just
Thank you for your tips this is the first Pajero I got a few weeks ago for a good price bearing in mind that there will be issues. The Spanjaard does one just remove the air cleaner and spray it in.I can not find the MAP sensor do you by any chance know where it is
Keep well
Dirty Dog
Vehicle: 2007 Pajero DiD LWB
Mon Jan 11, 2021 10:46 am
The MAF sensor is on top of the air filter. It has the wires running into it. The MAP sensor is normally on top, next to the diesel filter, and is a small black sensor with wires running into the top and a pipe running from it down to the inlet manifold. It is also a good idea to clean out the pipe, as it can also get blocked.
Login · Register
Latest Posts
