Hi Guys
With the winter here, and, the need to switch on the headlights sooner, I noticed the dashboard lights (aircon console etc) flash on and off. The dash lights keep flickering on and off. Also, when engaging the brights at night, the first 2 "pulls" on the indicator does nothing.
Any ideas?
Gen4 Exceed 2016
Tried to upload a short video, but, struggling
Gen 4 Flashing Dashboard lights
- akieviet
- Country: South Africa
- Vehicle: Pajero 3.2 GLS 2016
- ROBNICK@50
- Vehicle: Shogun 3,5 GDI
Post
Re: Gen 4 Flashing Dashboard lights
Hi you haven't said if engines running or stopped. Do the interior lights also flicker. I've included couple of schematics uses same principle from a gen 3. Looks like you have a loose connection earth or positive connection. Supply on these come from 40 A fusible link fuse box will indicate on lid. Hope you come right
Sent from my SM-A205F using Tapatalk
- Rob Humphry
- Vehicle: 2008 Pajero Gen 4 LWB
Post
I had the same problem on my Gen 4, it only got worse. The issue on mine was the indicator stalk making a bad/intermittent connection. I tried removing the stalk and refitting but made little difference.
I then priced a new indicator stalk from the agents (R3k plus) but found one in a used spares shop in Pretoria for R850. Problem solved.
I hope this helps
Rob
I hope this helps
Rob
