I won't comment on the
Its the air pressure outside the width of the rim that gives that floating feeling...
If "handling" refers to cornering stability, he might have a point.
A tyre with a tread wider than the rim does handle like a "brick on marshmellows".
The high profile and wide tread is exactly what we need for our SUVs. The large cross-sectional area has a very good cushioning effect, to the detriment of outright "handling".
In a straight line, the effect would be very small and should definitely not cause swaying.
In a "moose" test (fast left-right-left movements) the "balloon" tyres will be worse than say 45 profile tyres, but our SUVs are not designed for that type of driving.
Any deficiencies in his steering/suspension setup will be accentuated by the high/wide tyre profiles.
Different tyres will react differently. The stiffer side walls of eg BFGs (sorry Simon!) would be better than the soft side walls of other (lesser) tyres.
It does however definitely NOT cause swaying under normal circumstances.
My Gen1 has 12.5" wide 33" tyres on 8.5" wide rims, and it is as stable as anyone could expect of that type of vehicle.
Look at quad-bike tyres if you want to see "muhrse" ratio between rim width and tyre width!
Missing Attachment
BUSTED!
