Gen3 vs Gen4 suspension comparison
Re: Gen3 vs Gen4 suspension comparison
Sho, anybody care to give the less technical of us a summary :)
It seems like the rear differs a bit...
Are those numbers, the mitsu part numbers?
Karl
from what I can see the suspension is just about identical.
The gen4 has more body insulation for noise reduction but mechanically they are just about the same - maybe with the exception of spring rates.
The numbers are PNC (Part name Code) numbers. The actual part numbers may vary based on year models, recalls and redesigns.
hence, if the PNC number is the same the actual part number may vary but it may be interchangeable (for instance a harder/softer suspension bush with the same physical dimensions)
Davidvan
Thanks Marius, this is awesome.
Do you have access to confirm dimensions of these components, especially for comparison and review for rear suspension spacers for Gen3 and Gen 4 models.
David
