francoisd
Replacing the ball joints on a Pajero
Has anyone replaced the upper & lower ball joints on earlier Pajero models (2000)? Is there anything specific to look out for? Does one need special tools to do the job?
Re: Replacing the ball joints on a Pajero
It's similar to most double wish bone suspensions - a proper pain in the butt!
Jack up, put on trestles, strip front hubs off, remove, replace in reverse order (if you have the correct parts ;) ), have the alignment adjusted.
Sometimes you are lucky and you get the old ones off quite easily, sometimes it will take a combination of the following:
  • swearing
  • hitting with a FBH
  • skinned knuckles
  • believing that they can't actually come off
It's one of those jobs which I have done enough of to pass it on to the local suspension shop. :oops:
Whatever they ask, is a bargain!
