My 1998 Pajero GLS has an issue. When I try to close the driver side power window, the glass goes all the way up smoothly and when it reaches the top it goes back down 1/2 way automatically. I can manually close it bit by bit and have to stop at the top, otherwise it will reverse. I've checked the rubber channel and the glass position. Everything looks clean and in good condition. I've also tried to "reset" the window motor using many procedures but nothing has worked. I couldn't find the correct procedure to setup the upper limit properly
Any Ideas?
