Yes it is in fact the braking system that overheats due to excessive traction assistance.Andre, presumably the TC that you refer to that overheats is the traction control and not the torque converter?
This is quite a bother at times. I often happens when you push for the last few meters on severely poor surfaces. I hate this. That is why difflock is preferred. TC is fine while its there but it can leave you in trouble.If the temperature in the braking system increases excessively due to continuous brake control on a slippery road surface, a warning buzzer will sound intermittently to warn the driver. If driving continues in spite of the buzzer and the temperature in the braking system increases further, the TC indicator lamp will illuminate, the warning buzzer will sound continuously for approximately 3 seconds, and active traction control system operation will be suspended to protect the braking system.
Sit dit af.........sit dit af!AndreBenson wrote:I had a similar situation this weekend.
Par a little bit of momentum. the auto box was great, before the engine lost too many refs it would drop a gear weather it was in trip-tronic or not. i didn't make it up the sand, but got further than a jeep rubicon and a 3.3 Nissan.
What I did find was how happily the engine revved at 5000rpm going up the sand. What I did not enjoy was my TC screaming at me 75% up and I could see the engine temp picking up.
Tried it in 4H 4HLc and 4LLc. Fynny enough 4HLc got me half way up switched to 4LLc and it got me up another 50% or so. Then she just bogged down in the sand.
What can one do to stop that TC from overheating so quickly....
Hmmm One thing I have learned in sand - perhaps it is because I drive a petrol manual... fast as possible is worse than too slow..KaiV wrote:Go as fast as possible WITHOUT spinning tyres. Once you have some momentum gun it with all she'll give you
without momentum in sand you might aswell not try.
