Page 2 of 2
Re: Sudden Clutch Failure on Did - Please help
Posted: Mon Dec 20, 2010 11:22 pm
by Wessel
:oops: Yep there she goes, and yes the "alles loop reg" being towed behind me made me feel slightly better.. ;)
Paj booked in, praying I'll still have her back tomorrow - precious holiday running out..
Posted: Tue Dec 21, 2010 9:12 am
by Wessel
CATS wrote:At just over 200 000km on the manual transmision I would also have the retaining plate checked and replaced. Mine started slipping out of first gear every now and again at around 210000km and from the gearbox guy they seem to be prone to start this around this mileage. See this post : https://www.pajeroclub.co.za/forum/view ... ning#p6421
Hi Cats,
Vehicle currently at dealer, box still not out. Technician scheduled to do another service first. Asked workshop managed to check the points you and Gerrit mentioned. Says they routinely replace the rear crankshaft seal.
He says they don't adive you to open and strip the gearbox unless there's something wrong. Told him what I read on the forum. He said if retaining plate were giving problems it would start with a whine. (Didn't see that in you related thread though).
So, again choices. Would prefer having it done preventatively. Time is also a bit of an issue - they're sqeezing me in at the workshop and I was really hoping to be able to get back to my family tonight if they manage to to fix problem in time.
Any suggestions as to what I should do ?
Posted: Tue Dec 21, 2010 9:34 am
by tonton
Wessel,
If it is JJ Smit you are talking to, you can go with his advice.
He knows his Pajero's, and he has the advantage of physically seeing the car now.
Posted: Tue Dec 21, 2010 10:37 am
by Wessel
Hi Anton,
Usually deal with JJ, but he's currently on leave. Brian is helping me now, and has really been helpful so far.
Posted: Tue Dec 21, 2010 3:44 pm
by Wessel
Just got a call from Mitsu. Flywheel + clutch had to be replaced.
Decided to bite the bullet at just under R22 k and gave them the go ahead. Hopefully they'll have her ready before closing time.
Posted: Tue Dec 21, 2010 4:20 pm
by tonton
Wessel wrote:Just got a call from Mitsu. Flywheel + clutch had to be replaced.
Frikkadel - that's a lot of moolah.
Now you'll be set for another 200000 km's!
Posted: Tue Dec 21, 2010 7:20 pm
Ouch
But at least it is not something else. If they are not opening the box then leave the retaining plate till later. It wont let you out in the cold and in need of a towtruck. It will only start to irritate you by slipping out of first gear on some pullaways if it is out of spec.
Let me know if your clutch laso comes out as light as feather like mine when I had mine done! Pure bliss.
