Page 2 of 2
Re: Pajero RHD Inner Shaft Bearing disintegrated
Posted: Tue Apr 23, 2013 7:57 pm
Well, just as I was about to sell my beloved Pajero I picked up a horrible vibration in the back. Turned out to be the rear inner shaft bearing.
While in there I also replaced the rear suspension bushes and diff mountings as they looked decidedly tired after 285000km.
With the added expenses spent I have decided to keep the vehicle a little longer although I had plenty of interest and withdrew it from the market. Maybe she was just getting back at me for even thinking of selling her:lol:
Posted: Tue Apr 23, 2013 9:01 pm
Damn straight! My pajero kicked the treg in the cylinder when it saw it was being traded in. Cost me a penny to sort that nonsense out!
Posted: Wed Apr 24, 2013 8:04 am
by JohanV
So glad i am not the only one suffering from Pajero kickback. :lol:
Talked about selling mine last week and next moment a seal on the rear diff popped.
Posted: Wed Apr 24, 2013 9:08 am
I'm most definitely keeping my Pajero - will somebody please pass that on to my car :D
The wife's RunX almost got swapped for a new Fiesta - 3 cylinder, 1000cc and 91kw :o petrol motor
Posted: Sun Apr 28, 2013 9:19 pm
by andrew.ashton
CATS wrote:Well, just as I was about to sell my beloved Pajero I picked up a horrible vibration in the back. Turned out to be the rear inner shaft bearing.
Hi CATS,
Excuse my ignorance. Is that the bearing that the companion shaft runs in? What diff oil were you running? Have you ever had a companion shaft pop or the oil seal fail? Have you speculated on what could have caused that failure?
For the bushes did you use OEM or 3rd party polyurethane bushes?
Re: Re: Pajero RHD Inner Shaft Bearing disintegrated
Posted: Wed May 01, 2013 12:41 am
Hi CATS,
Yes it is the bearing that the shaft runs in if I understand it correctly. Diff oil was as per Mitsu spec, not sure exactly as I had it done at a suspension specialist, Syds Suspension Parts in Pretoria. I had the companion shaft pop out many years ago and had the upgraded shafts and clips fitted then. Never ran dry on oil or had a seal fail in its life. I suspects that the bearings got damaged while I ran my vehicle with longer coils plus spacers for a while giving it too much of an angle. I have subsequently taken out the spacers again. The failure was not catastrophic, it just made some noise when cornering but still went well.
I replaced the bushes with polyurethane ones which definitely gives a bit of a firm/harsher ride than I think original rubbers would have done, but not uncomfortably so.
Posted: Sun May 05, 2013 3:25 pm
by trekker1
Yes, I did the same job on my Gen 1 for the same reason, just days before a big off road trip where 4WD was essential.
I purchased the 2007 sealed bearing (rubber seals) from a bearing shop, and the shaft seal 62 x 78 x 7 double lip from a seal shop. No issues since.
