It was in the region of R600 but I will have to check the paperwork for the correct amount. Dropped the car off in the morning and collected at 15:00.SimonB wrote:Johanjbeez wrote: Replaced primer pump, reconditioned dieselpump and reconned startermotor
How much did the recon starter motor job cost you?
Problem was created by myself with the faulty fuel system and cranking the motor to long to get it started. Started worked fine when cold but once the engine was hot it was a nightmare
