Page 2 of 2
Re: Alignment woes...
Posted: Mon Mar 01, 2010 5:17 pm
by SimonB
Ok, so now I am thinking if I am going to do the ball joints I might as well do the rest...
Tonossons in Claremont quoted me thus for the parts
Lower Ball Joints R175
Pitman Arm R161
Idler Arm R350
Tie Rods Inner R195/set
Tie Rods Outer R177/set
Now you 4e's have done this recently. Any photo's, hints trips, gotchas?
Posted: Mon Mar 01, 2010 6:30 pm
SimonB wrote: Now you 4e's have done this recently. Any photo's, hints trips, gotchas?
Nah, I did not take photos.
Although there is not much that can go wrong.
I would
  • clean the steering/suspension parts as well as you can (on the vehicle). I hate working on dirty parts
  • mark LHS and RHS components with white paint
  • take photos from all angles
  • measure ball-joint to ball joint distance on the tie rod (to set it close to correct, so that you can drive to the wheel alignment shop without ruining the new Kumhos)
  • put Pajero on trestles (chocks behind rear wheels, handbrake on)
  • mark the position of the Pitman arm on it's shaft (not critical, but makes centering of steering wheel easier)
  • remove wheels
  • remove all bits (4lb hammer, ball joint splitting tool etc)
  • the Pitman takes a bit of hard moering :D
  • place on floor and take more pics.
  • disassemble
  • fit new bits, ensuring thread usage is same on both ends of the rod
  • set distance as measured previously
  • make sure tie rod ends are locked properly
  • fit split pins to castle nuts
  • re-assemble to Pajero (check manual for torque specs)
  • grease idler (if it has a grease nipple)
  • have alignment done (make sure they centre the steering wheel)
  • enjoy the savings in $$s
  • enjoy the 'solid' feel to the steering (if there is still some 'looseness', the steering box needs to be set a bit tighter (another subject)
Posted: Mon Mar 01, 2010 11:06 pm
by HBannink
Hammer = Problem solver :D
The bigger the problem, the bigger the hammer :twisted:
Posted: Tue Mar 02, 2010 7:27 am
HBannink wrote:Hammer = Problem solver :D
.... and if you can't fix it with a hammer, it's an electrical problem! :D
