Page 16 of 21
Re: Whatsapp Group
Posted: Wed Oct 17, 2018 3:42 pm
by fungface
my number is +256794705901
please add me on the whatsup group
Thanks.
Re: Whatsapp Group
Posted: Sun Oct 21, 2018 8:14 am
by EugeneGen2
Hey Please add me to the group 083 2777 354. Thanks
Re: Whatsapp Group
Posted: Sun Oct 21, 2018 11:57 am
by GROBBIE
Please add me. Grobbie 0829528781 Thanks
Re: Whatsapp Group
Posted: Tue Oct 23, 2018 11:10 am
by Brown
Please add me 0026773870534
Re: Whatsapp Group
Posted: Thu Oct 25, 2018 9:55 pm
by Tunja
Please add me 0736090981 Thanx Ernie
Re: Whatsapp Group
Posted: Fri Oct 26, 2018 10:56 am
by MikaZA
Please add me: 0823166558
Re: Whatsapp Group
Posted: Thu Nov 08, 2018 11:17 am
by Oupa
Good day
Add me again please.
082 873 8103
Riaan
4x4 Driving advice needed
Posted: Thu Nov 08, 2018 11:34 am
by Oupa
Good day guy's.
I have a 2008 3.8 V6 GlS, planned a trip in December to Clarens and Lesotho and intend doing some off road while there, my neighbour informed when using 4x4 I have to disengaged the ASC.
Is he correct or what do you recommend.
Furthermore I planned to service the vehicle(oil, oil filter ,rear axle, transfer case and auto box) but the dealer informed me the fuel filter is in the tank) vehicle's consumption is very high, and idling is very erratic, replaced the air filter just recently a few weeks ago.
Any pointers or advice will be appreciated.
Greetings
Re: Whatsapp Group
Posted: Thu Nov 08, 2018 6:29 pm
by KurtG
Incorrect information has been provided.
On the Superselect one has 4 settings to choose from:
1. 2H
2. 4H
3. 4HLc
4. 4LLc
Positions 1 and 2 will engage ASC if wheel slip is detected, by cutting engine power. Here you can press the “ASC off” button to help you keep the engine power from cutting, but it not safe to do so unless you are prepared to control the potential high speed slide yourself.
Positions 3 and 4 when engaged will automatically switch off the ASC.
So if you are on the rough stuff, and you have selected the appropriate setting, there is no need to manually disengage the ASC.
Position 2 is open centre diff (70/30 front to back torque), position 3 is locked centre diff (50/50) so when you are on the rough stuff (i.e. worse than a gravel road) then you must select 3 or 4 (4 = low range).
Do not select 3 or 4 when on solid ground like tar or cement roads, you will create drivetrain windup and potential damage.
2H or 4H can be used on tar, no problem. Remember to engage N when moving to 3 or 4.
Whatsapp Group
Posted: Thu Nov 08, 2018 6:30 pm
by KurtG
The fuel filter is part of the fuel pump I am led to believe, which is in the tank I think.
