Page 32 of 74
Posted: Thu Sep 12, 2013 9:04 am
by Stranger
Took my drawer system out the back, instant lift. That thing is quite heavy.
Re:
Posted: Fri Sep 13, 2013 5:38 pm
by andrew.ashton
Gemaskerde Tuinvurk wrote:Got my MadMan EMS installed today! So much info
Sent from my GT-I9300 using Tapatalk 4
Hey GT - you just trying to make us envious?
Which sensors did you get connected up?
EGT +
And where did you fit them?
If you have a chance I would love to see some pics.
Re: Re: Re:
Posted: Sun Sep 15, 2013 10:24 pm
by Gemaskerde Tuinvurk
andrew.ashton wrote:Gemaskerde Tuinvurk wrote:Got my MadMan EMS installed today! So much info
EGT +
Wanted to do it at Mitspro, but when they asked for the wiring diagram I thought it best to install at the guys I bought it from - Landyonline.
I thought they did quite a neat job. Sensor for EGT is however installed post turbo, so readings are about 100degC less, but Sho - can't believe how sensitive they are to drive style.
Also noticed, it takes quite a while for the EGT temp to go below 200degC, when stationary before switching off. Anyone know the rule of thumb for ideal temp before turning off?
I also now get oil temp pressure and temp, as well as coolant temp.
The EMS 1 is fitted to my cubby hole with enough length for me to take it out and hold it from the driver side.
Posted: Sun Sep 15, 2013 10:27 pm
ooh - and with this
http://www.arduino.cc/ - the possibilities are endless!! (budget linked)...
Might build by own unit and sell the EMS1 eventually
- long term project though.
Posted: Mon Sep 16, 2013 9:03 am
by andrew.ashton
Gemaskerde Tuinvurk wrote:ooh - and with this
Thanks GT.
Great minds think alike.
I have also been looking at Arduino based do-it-yourself solution - spent the last two weeks reading up on it.
As well as online, you can also buy Arduino's and various shields locally at a few places, including Communica in Samrand, Centurion.
Was thinking of making it a 1-DIN form factor then can fit in the centre console.
Is the EMS1 based on Arduino?
Posted: Mon Sep 16, 2013 9:40 am
Don't think so... But I'm sure you would be able to read the sensor output (it's supposedly some type of standard sensors)
Re:
Posted: Mon Sep 16, 2013 9:46 am
by andrew.ashton
Gemaskerde Tuinvurk wrote:Don't think so... But I'm sure you would be able to read the sensor output (it's supposedly some type of standard sensors)
The sensor for the EGT is a type K thermocouple. There are designs online for signal conditioning the type K thermocouple (with cold-junction compensation, linearisation and amplification) to an Arduino analog input.
Posted: Mon Sep 16, 2013 10:54 am
by MThompson
Programming the Arduino is easy...getting all the sensors etc is not so easy. If someone can source some good sensors, I'll be willing to program the arduinos.
Posted: Mon Sep 16, 2013 3:17 pm
I've got the sensors installed, and programming is not an issue. TIME is my biggest problem.
But thanks mr Thomson!
Posted: Mon Sep 16, 2013 3:19 pm
Think we are going OT here - need a separate arduino thread!!
