Packing system for a LWB
Posted: Sat Jul 11, 2009 12:52 am
by KaiV
I have been looking around at what is available and have decided against buying someone elses expensive goods. I am a long way from finished, but the idea is once I am back in SA, I will:
put on a thicker board,
cover with carpet,
add an area to relocate the dual battery wiring too,
add an inverter,
see if I can add a water tank between the board and rear seats (at the moment chairs fit in nice:))
add a fridge slider
And all that before August when we are hitting the road to Namibia for four weeks
Re: Packing system for a LWB
Posted: Thu Jul 30, 2009 8:32 am
by KaiV
OK, spent a couple of hours in my workshop over the last few nights.
I changed the frame, cut and fitted a larger 19mm plywood plank on top, added some braces on the rear of the frame, added a plate to bring the electrical connection to the back, added a 50L water tank and covered the lot with a carpet:)
Here some pics, though from a cell phone. Will post normal camera pics tomorrow.
Posted: Thu Jul 30, 2009 8:34 am
by KaiV
Still have to get a fridge slide (on the right) and a couple of tie down points.... then I'm good to go:)
Posted: Wed Jan 23, 2013 3:18 pm
by CJJD
Perhaps a bit late but thanks for sharing, more or less exactly what i am planning to build.
Posted: Wed Jan 23, 2013 8:30 pm
by cloyd
KaiV
Welcome to the DIY club. At one stage I thought I was stupid for designing and building my own equipment! It seems like everybody else were/are buying stuff off the shelf. At least when I design and build I get what I want and not something that somebody else with maybe some experience?? designed. I must add that all my DIY equipment are first issues with no problems thusfar.
Cloyd
Posted: Wed Jan 23, 2013 9:51 pm
by Gemaskerde Tuinvurk
I will be trying the DIY thing for a battery box in the rear storage bay.
What thickness do you recommend and what type of wood? Plywood? 17mm? Note that it will only hold a battery, and I wil be building in the connectors for the electrics... Maybe only 10mm needed?
Posted: Fri Jan 25, 2013 9:16 am
by SimonB
Gemaskerde Tuinvurk wrote:I will be trying the DIY thing for a battery box in the rear storage bay.
I built my battery box from 6mm ply
