Upper radiator hose size?
My upper radiator hose is this one
and I want to get one of these for a coolant alarm/electrically switched fan.
but i need to know what size as they sell the following sizes
28mm
30mm
32mm
34mm
36mm
38mm
40mm
Re: Upper radiator hose size?
Good now we know what size the hose is but elaborate on the contraption you want to fit over it, just maybe I could use it to turn on my noss :twisted: .
Serious what does it do, how does it do it, and what else canit do? It seems like something that might just be handy, oh cost as well :?:
Henk Bannink
Looks like a section of tube containing a temperature sensor. It would require a section of hose to be cut out in order to insert the tube into the water line.
Gerrit Loubser Image
This is the ebay link
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 031wt_1165
2 are on the way. One for my gen2 3.0 v6 and one for dad's gen1 3.2 DiD.
Some of the descriptions are pretty funny but as long as it doesn't bulge under pressure and I can seal the thread then it will serve the purpose.
I want to use it as extra temp sensor or even a coolant loss alarm.
Brand New High performance Hose sensor Gauge Adaptor for high temperature Radiator!!
Product: NEW 36mm Water Temperature Gauge Hose Sensor Adapter
Size: 36mm = 1.42 inch
Sensor Thread Size: 1/8 NPT
Length: 76mm = 3 inches
Application: 4AG, B16, B18 Engine, and H22, 3S, 5E, GS Engine.
- This product is good for Honda Accord, Civic and Acura Integra etc..
We sell different sizes of this adaptor by checking my other auctions.
Features: 1. Aluminium Alloy 36mm Outer Diameter
2. Stainless Steel Clamps
3. Easy Installation
4. Made in Taiwan and High Quality Control level
((( Same as the picture you saw, what you see is what you get!! ))
All sales final and No combine shipping.
Thanks for your business and Have a nice day.!!
Despite the appearance of frivolous banter this is something that I have been looking for for a long time and up to now I had to make do with a section of steel pipe with the required fittings welded in and having to replace every so often. Thanks for the tip Marius :D
Henk Bannink
