JP1
Smelly Vent system on CK3 . . .
Good day Gents, and the odd Lady or 2 ;)
This question was asked by myself on 4x4comm, but since I'm desperate for a solution I'm asking here too . . . .
"Eish, I've now had it, my sinusses are stuffed, my ears are stuffed ( from SWAMBO's complaining ) and I don't have a solution yet . . .
The ventilation system on the Paj 02 model smells extremely dusty, aircon on or aircon off, doesn't matter. Ok, ok, before everyone jumps on the pollen filter behind the cubbyhole, I've cleaned and replaced more than once . . . . any other suggestions or ideas perhaps ? . . . . . . . . . . . . . . . PLEASE ?? "
Re: Smelly Vent system on CK3 . . .
Johan,
1. Ek het dieselfde "probleem" met my 2004 3.8 GLS gehad. Die vervanging van die filter is stap een. Die volgende stap is om die waaier self skoon te maak. Die stof pak op die "lemme" saam en met tyd val dit af en beweeg uit deur die luguitlate. Hierdie is nie die maklikste proses nie want 'n m,ens kan slegs 'n klein gedeelte van die waaier op 'n slag sien. Gebruik 'n fyn / klein borseltjie. Dit vat tyd maar is die moeite werd. Die ander punt is om met hoëdruk lug die ventilasiepype skoon te blaas. Ek het my tuin blare blaser gebruik en is nou te vrede dat die lug weer redelik skoon is. Probeer gerus.
Groete, Cloyd.
Johan
You can also make sure that the aircon drain pipe is not blocked. I had this once in a Corsa and the putrid water smell was very much evident until we found the drainage pipe blocked. With the pipe cleared the smell disapeared after a while as it dried out properly.
JP1
Thanx guys, I'm going to tackle the drainpipe immediately and will have a look at the rest tonight at home.
Will report back once it is solved.
Site Admin
Also have a look under the condensor of the aircon... if the mat under it is damp you definitely have a blocked drainpipe.
If it is blocked you can easily unblock it, and then I would run a can of aircon refresher through the vehicle
Allegro
Ag neewat, ek het 'n baie beter manier gekry.
Doen as volg:
-Haal die dem pollenfilter uit.
-Kry die oortollige stof uit die filter uit.
-Sprinkel 2 tots Captain Morgan oor genoemde filter
-Plaas filter terug in sy plek
-Siedaar heerlike reuk van CM deur die Paj (hic) :mrgreen:
JP1
*hic*
*burp*
Dit wasjh nou goeie adviesjh gawieshj :D
