Wiring diagrams for 2006 3.2 DID LWB GLS Auto??
Posted: Fri Nov 19, 2010 5:39 pm
by Entabeni
Some weeks ago I came across a Post which had available a full set of wiring diagrams. A file size of around 500MB was mentioned i.e. too large to download but which could fit on a CD. Unfortunately I neglected to note where on the Forum this was and now I cannot find it! I would much appreciate being directed to it.
Thanks in anticipation, from Entabeni.
Re: Wiring diagrams for 2006 3.2 DID LWB GLS Auto??
Posted: Fri Nov 19, 2010 6:22 pm
send 4ePajero a PM
Posted: Wed Dec 16, 2015 6:30 pm
by chinas
I need the same thing, but I can't send any PM as I am new on this forum. Have you find wiring manual for 3.2 DiD engine?
Posted: Sun Jan 03, 2016 8:38 pm
by Nick Gibson
chinas wrote:I need the same thing, but I can't send any PM as I am new on this forum. Have you find wiring manual for 3.2 DiD engine?
Send me your email address, will send them to you.
Posted: Sun Jan 03, 2016 8:44 pm
by KurtG
Slightly off topic but does the plug under the seat of a Gen4 that disconnects the beep sounds when starting (without the seat belt on) affect the airbag operation in any way?
Posted: Mon Jan 04, 2016 9:12 pm
by Nick Gibson
gerbek1 wrote:Slightly off topic but does the plug under the seat of a Gen4 that disconnects the beep sounds when starting (without the seat belt on) affect the airbag operation in any way?
I would be hesitant to do that, airbags might not deploy in an accident if the srs ecu picks up that the driver or passenger isn't buckled up due to the seat belt sensor being deactivated.
Posted: Tue Feb 16, 2016 2:42 pm
by 4x4stuff
Hi Nicholas,
Will it be possible to send me the info on the PAjero wiring diagram as well? jp at jpit dot co dot za.
We have a 2003 Gen3 with 3.2diD, NON-commonrail. THe engine ran into some trouble and after exhaustive searching, could not find a NON-commonrail engine. All we found was a 3.2diD commonrail motor from wrecked PAjero SPort, complete with main harness, computer box, ignition, pedal(fly-by-wire type) and extra sensors (assume air-mass / air temp sensors).
Right, so the engine install is bolt on - well, relatively. Minor modifications to engine mounts, minor pipe deivations etc...
Following advice, we are aware (or led to believe....??) that:
1. The original harness stays intact, except for engine wiring.
2. The new ECU will only take care of engine management, and will run simultaneously with original harness.
3. ingition will be set up that the turn of original key, will provide power to new ignition, ECU and to the starter, with orignal harness intact.
4. "display stuff" from the engine (REVS, speed, engine temp etc) need to be tapped in from the new harness....
At the moment, we are stuck without a wiring diagram of any sort for gen4/pajero sport harness, so do not know which of the 100's of wires/plugs do what. also do not have a wiring diagram of the gen3, so if we find what we are looking for from the gen4 wiring, do not know where it goes.....
Any help, advice, contact numbers, prayers or the like, will be much appreciated. Rewards also applies, monetary or otherwise.
JP, zero seven one 364 eight 5 9 four or email jp at jpit dot co dot za
Posted: Wed Feb 17, 2016 9:38 am
by Dirty Boy
Be very careful with unplugging stuff under the seat. Some vehicles (LR Disco for sure)has seat position sensor that the ECU picks up and tell the airbag how much to deploy ie a short person near the steering wheel does not need 100% inflation vs a tall person sitting further back. Then there are also plugs for the seatbelt pretensioner, seat heaters, movement, seat airbags etc. Just be sure of what you are unplugging.
Re: Wiring diagrams for 2006 3.2 DID SWB GLS Auto??
Posted: Sat Jul 16, 2016 11:25 am
by gerto
I want to install daylight driving LED light, so they must come on after startup
I need to know where to make this connections
Kind Regards
Gert Olivier
Re: RE: Re: Wiring diagrams for 2006 3.2 DID SWB GLS Auto??
Posted: Sun Jul 17, 2016 7:46 am
gerto wrote:Hi
Kind Regards
Gert Olivier
Gert
From my internet reading the only wire that suit your requirements on a gen4 Pajero is the wire for the wipers.
