Explain Torque versus KW in one sentence.
Posted: Wed Nov 24, 2010 2:32 pm
I see it as
"The more torque you have the less revs you need to do work (KW)"
Re: Explain Torque versus KW in one sentence.
Posted: Wed Nov 24, 2010 2:35 pm
by tonton
I see it as engine-momentum vs brute power...
Posted: Wed Nov 24, 2010 2:39 pm
by AndreBenson
hehehe, I just want lots of both!!!!!
Posted: Wed Nov 24, 2010 2:49 pm
by Mcnoogle
I see it as Torque = crawling power, KW = overtaking on the highway power.
Posted: Wed Nov 24, 2010 3:02 pm
Torque is the turning moment / 'twisting force' (Nm) excerted by the crankshaft, while the power (kW) is the amount of this force being excerted (work done) over a period of time.
Posted: Wed Nov 24, 2010 4:34 pm
by Cas
Sitting in a diesel,you torque(nm) about the bliksem that flew past in a petrol (kw) :lol:
Posted: Thu Nov 25, 2010 8:56 am
Gerhard,
You offered this explanation some time ago on another website. I was convinced that you had solved the riddle for me.
BUT, the more I think about it, the more your explanation sounds like the effect of gearing.
May I ask, how and what is measured when torque and power figures are published?
Roelf
Posted: Thu Nov 25, 2010 9:29 am
The only items necessary to measure and engine's output (torque as well as power) are
  • torque
  • rpm
A dyno measures the turning moment an engine has, by seeing what brake force on the rollers it can resist.
There is a direct relationship between torque, power and rpm.
Power (kW) = Torque (Nm) x rpm / 9549
Gearing: In classic physics, a 'gearbox' is called a 'torque-multiplier'.
The torque (turning moment) in a low ratio is obviously higher than in a high ratio.
Posted: Thu Nov 25, 2010 1:12 pm
Gerhard,
FINALLY.... a formula!!!!
The apple has at last fallen on my head.
Thank you
Roelf
Posted: Fri Nov 26, 2010 11:03 am
by Wilddog
Its simple
Torque is the forced that gets things going, Power is the force that keeps things moving :geek:
Torque is actually a product of the engines ability to move air through it. One reason that Diesels have more torque is that they do not have a throttle valve, so throttling losses are minimum. Many newer vehicles have variable inlet manifolds, these are manifolds that can change their length (or at least change the distance the air travels).
Long manifolds-low rpm= high torque
short manifolds-high rpm= high power
Hope this helps.
