Outer CV joint replacement
Posted: Tue Nov 30, 2010 12:38 pm
Got the boots torn and kept on putting off the replacement (still have the extra set of boots) until the dreaded cluck-cluck showed. With this I also got a weird wheel wobble and that prompted me to start a redo of the front suspension. Geared with enough info from Hbannink' posthttps://www.pajeroclub.co.za/forum/view ... =25&t=1274,I set of to the local spares dealers.
Apart from the no show at the local stealer , none of the spares suppliers could/would supply me with any parts. Got my backside in gear and went to Goede Hoop Onderdele http://www.gho.co.zain Brackenfell. What a pleasent suprise. Got everything I needed with a smile and at a good price too. They also stock the complete shaft as Mitsu does but will let it go for just under R1k.
Here is my list of goodies with partnumbers and prices:
Description Part # Price
Outer Tie Rod Ends (Pair) TR5557 R 111.19
Inner Tie Rod Ends (Pair) TR5556 R 184.23
Lower Ball Joint (Each) BJ1060 R 206.15
Upper Ball Joint- Right (Each) BJ1073R R 163.52
Upper Ball Joint-Left (Each) BJ1073L R 163.52
CV Outer MTS Pajero/Colt U1F (Pair) GMS-3904 R 335.95
Sub R1 370.71
14 % R 191.90
Total R1 562.61
The Idler and Pitman Arms were fine and needed no replacement. While stripping we found the result of the wobble. A bearing on the right front inner shaft has disintegrated. Basically because the dustcover was not fitted properly and came loose and exposong the bearing. This according to the workshop manager. Mitsu does sell these as seperate parts and hopelfully this will be delivered this afternoon as promised.
Inner dust seal (5) R 41.00
Bearing (2) R 105.00
Outer Dust Cover (3) R 31.00
The best quote in Paarl for Cv replacement was R1200/wheel. I thus decided to use the bit that was "saced" and ordered a replacement radiator from SR Radiators (021 862 5965).
Genuine - R 2860.00
Aftermarket R 1 350.00
All now that is left is to get everything fitted before Sunday's outing. It's been a while since I have doen any trips.
Sub R1 370.71
14 % R 191.90
Total R1 562.61
Genuine - R 2860.00
