I'm sure it will add stability and extra safety to the ride.
7eZFujwrYY4
http://www.ultraracing.com.my/Bars.asp?ID=3795
I don't know if they can ship to SA or if there is an equivalent in SA
could you elaborate? I was under the impression that was the main cause for the instability.Gerrit Loubser wrote:I am not convinced that adding roll stiffness at the rear will improve matters...
This might very well be the a contributor. Many have reported an improvement when fitting better dampers, but not all have found this to completely solve the issue, if I recall correctly.RoelfleRoux wrote:1)I came to a personal conclusion that the shock absorbers were woefully inadequate. That the tail would unexpectedly step out because dampening failed on a pair of overheating shocks. Does the fact that ridiculously low tyre pressures often seems to help, support my shock-theory?
An engineering definition of handling stability would be something like the ability of a vehicle to react in accordance with the driver's steering inputs in a predictable and not in a divergent manner (e.g. the vehicle would not attempt to keep reducing the corner radius until it spins) and would return to running in the straight ahead direction when the steering s neutralised. This means that the anti-roll bar can play a role by tuning the handling between a bias towards oversteer and a bias towards understeer as described in my previous post. Adding an anti-roll bar could improve or reduce vehicle stability in this sense, depending on the initial vehicle design.RoelfleRoux wrote:2)If corrugations are taken perfectly parallel to the acle, then the anti-roll bar will not have an effect, but if the corrugations are not parallel, or if the road is slightely rutted as well, then the wheels start to perambulate on their own. Is it possible that an anti-roll bar will be helpfull under those conditions to stabilise the car?
Normally Panhard rods are arranged so that they are as close as possible to horizontal in the mid-ride position. Designers also attempt to make the Panhard rod as long as possible. Both of these things help to limit the lateral motion of the chassis relative to the axle as the suspension is deflected. I have not noticed this about the Fortuner, but if the Panhard rod is at such an angle that it induces visible lateral motion over a speed bump, it definitely is not good.RoelfleRoux wrote:3)The angle of the panhard rod also makes me wonder (or is it wander, like a Fortuner tail). I was behind a Fortuner the other day at idle speed over speed bumps. The lateral movement as the suspension is depressed at the rear is scary. The passengers literally sway from side to side. Could that also impact on rear instability?
