Gen3 : Clean your A/C filter
Posted: Tue Feb 01, 2011 8:32 am
I came across this link
http://www2.pajeroclub.com.au/forum/sho ... hp?t=15120
I dropped the lower glovebox removed the 2 screws, cleaned under a powerful tap with water only and voila.
The amount of dirt that was there was shocking and the extra blowing power I now have is incredible!
Well worth the 5 minute job!
Re: Gen3 : Clean your A/C filter
Posted: Tue Feb 01, 2011 1:46 pm
by Louwb
Thx, been looking for this. Much similar to other vehicles.
However, mine is empty, that is , somebody totally removed the filter !!
Any ideas what a replacement may be???
Thx
Posted: Wed Feb 02, 2011 8:13 am
by PeterH
I replaced mine in November and the filter only is R460 from Mitsubishi! Well worth it though!
They are apparently the only ones who stock such an item.
Posted: Wed Feb 02, 2011 8:30 am
Louwb wrote:However, mine is empty, that is , somebody totally removed the filter !!
That's what I did to my "pollen filter" on the Touareg!
The air is clean enough to breath, thank you.
Posted: Tue Aug 16, 2011 2:06 pm
by Denis
hi guys
i think i have the same issue here. and anyways you posted a link with picture; how can i get to see those pictures to make my work easier. i did get down to the glove box but i noticed that when i touched a certain sponge, it was brittle and kind of would break. i then didnt go any further.
I refilled the gas but at the dashboard, the air in not cool whereas the back part of the cabin, the air is preferably cool. i then suspected, clean the air filter would do. please post some pictures for the procedure
Posted: Tue Jan 03, 2012 2:47 pm
by Malcolm
Hallo all
Just cleaned mine as per the instructions. Most difficult part was squeezing the glove box to clear the lugs and drop it - scared something might crack ! I purchased my vehicle 2nd hand in September last year and now found a small piece of the countryside residing in the filter. Thanks for the tip. Any more input on adding a small dose of TSO to the diesel to reduce starting shudder ?
Rgds
Malcolm
Posted: Tue Jan 03, 2012 3:04 pm
no need to squeeze.
Just open the lid fully, then back 5cm and clip out the clips.
Posted: Wed Jan 04, 2012 7:39 am
by Malcolm
Thanks, also discovered this when re assembling it.
Rgds
Malcolm
