Hi Guys,
I finally got around to installing the long range tank I bought from CATS. It was a bit of a mission as I had to do it on my back in the garage at home, but otherwise fairly straight forward. I had to buy a fitting kit which consists of the brackets, pump, bolts and pipes. The kit cost R1400 which I thought was a bit of a rip off when you consider the retail price of everything in the kit (except the special brackets). The rear clearance is slightly reduced, which I dont mind, I use my bike for the serious bundu bashing adventures. If you have any questions send me a PM and I will be pleased to help.
The enclosed fitting instructions are self explanatory.
Wilddog
Evening Wilddog,
Steve, the price that you paid for your fitting kit is about halfway to the full price for a LR tank such as mine. However, if you are happy, then it is BG (bak gat). Be careful when you do off roading. The front runner tank is in a very vulnerable place.
Enjoy the extra travelling range,, Cloyd.
Wilddog, did you get an electronic "cut-out" for the pump included with the kit, or do yo just use an On/Off switch?
Johan
VW Tiguan 2.0TDi (Tar
Bushlapa Boabab 4.2 in tow
No. no electronic switch. I am using a switch. I have burn't one pump out already so have installed a light so I can, err, remember the pump is onLowRange wrote:Wilddog, did you get an electronic "cut-out" for the pump included with the kit, or do yo just use an On/Off switch?
I will let all know if I manage to come up with a solution. if there are any electronics fundis on the forum willing to share some knowledge, it would be greatly appriciated.
Thanks Marius,
I have mailed them for more info. My general concerns with a level sensor are 1, will the sensor react to the diesel (melt, disfigure, malfunction) 2, cutting a hole in the tank, firstly the issue of removing all the debris and secondly ensuring no leaks occur. The idea I am toying with is an electronic circuit that monitors (measures) the current draw on the pump, more current draw when the pump is pumping fuel and less when the pump runs dry. Once the circuit detects less current it switches the pump off. easy in theory but I'm struggling to design and put a circuit together that acheives this. Any electronic fundis out there help me out on this?
I'd love to help, but really don't have time at the moment...Wilddog wrote:The idea I am toying with is an electronic circuit that monitors (measures) the current draw on the pump, more current draw when the pump is pumping fuel and less when the pump runs dry. Once the circuit detects less current it switches the pump off. easy in theory but I'm struggling to design and put a circuit together that acheives this. Any electronic fundis out there help me out on this?
Basically you need a current sense resistor (very low value), and possibly a current sense amplifier, to increase the voltage measured across the current sense resistor. Then you can compare this voltage with a reference voltage using a comparator. This will give you a logic output, which you can use to drive a MOSFET (or relay).
I think the first thing to do, is to measure in detail how much current the pump draws when pumping, and when dry, and when you start the pump. The current might be strange at first, so you might need a time delay when you switch it on, before you start checking the current.
Not sure if this helps you at all...
2008 Pajero DiDc LWB GLS
Yeah! with you on this one Greg. I had already figured out the components (The internet is a wonderful tool)Greg_SA wrote:I'd love to help, but really don't have time at the moment...Wilddog wrote:The idea I am toying with is an electronic circuit that monitors (measures) the current draw on the pump, more current draw when the pump is pumping fuel and less when the pump runs dry. Once the circuit detects less current it switches the pump off. easy in theory but I'm struggling to design and put a circuit together that acheives this. Any electronic fundis out there help me out on this?
Thanks Steve
