calvinc
rear sagging
Hi Guys
Need some advice on my pajero 3.2 Did SWB 2001 model import, since i bought it the rear looks as if its very low, i have put 2 of the same pajeros next to one another and my 1 is definitely lower than the other although we have fitted new shocks some time ago, i am told to get new longer coil springs, i have enquired by Mitsubishi but was told that they are all the same. What else can i do, i was also told that it can not be adjusted, please see pic attached although i had 2 cases in the back, please advise. thanks Calvin
Re: rear sagging
Look at replacing the springs with an after market set like OME, they have a lifting effect on the vehicle and it does increase your load capacity
Henk Bannink
tonton
Re: rear sagging
You could also upsize on tyres. Those seem to have a lower profile than 275/75R16's?
