I'm looking to do some upgrades to my 2007 NS DiD SWB Pajero. The first upgrade I want to do is to install a front diff lock from ARB. I checked ARB's catalogue and it looks like the RD110 diff lock from ARB will fit my vehicle. I just need to confirm if this will work because 4x4 Mega world says there is no front diff lock for my vehicle. Is there anyone who fitted this to their vehicle?
Look I dont know a lot, but acc to me your car has and independed suspention in front, and not a solid front axle, so its not possible to fit a front diff lock, as their is no diff to fit it to. What does (NS) mean? maybe its a model I dont know? Maybe I just made my name ass
PAJERO 3.2 LWB GEN 4 AUTO
It has a diff.Bostokkelos wrote:Look I dont know a lot, but acc to me your car has and independed suspention in front, and not a solid front axle, so its not possible to fit a front diff lock, as their is no diff to fit it to. What does (NS) mean? maybe its a model I dont know? Maybe I just made my name ass
here is a pic of the layout on a gen3/4 front diff.
It is the same aa a solid front axle but just shorter in width and the rest is made up of shafts connected via CV joints - similar concept to a front wheel drive car with half shafts and CV joints.
Yes but its not the same at all as the SFA right?
for that reason a tazz has a front diff as well, with cv's.
but can you fit a Difflock?
2. Do you perhaps have the pic of the Sports front susp as well?
and now the Q ....can I fit a difflock in front?
hahaha..told you my name is asss
Megaworld are correct - there is no ARB Front Locker for Paj Gen 3 or Gen 4 models
See here
Bostokkelos, you can definitely for a D/L to an IFS vehicle - there's an ARB one available for mine
See here
The diff is the same concept whether it's SFA or IFS. It's just the stuff that boilts onto the side that differs.Bostokkelos wrote:Yes but its not the same at all as the SFA right?
Yes, you can get lockers for them. ARB Australia makes them so import may be expensive but it is possible.
Good reads
http://www2.pajeroclub.com.au/forum/sho ... php?t=3543
http://www.arbusa.com/uploads/PDF/onlin ... -RD110.pdf
http://store.arbusa.com/Assets/PDF/RD110_i.pdf
http://www2.pajeroclub.com.au/forum/sho ... php?t=4310
SimonB wrote:Megaworld are correct - there is no ARB Front Locker for Paj Gen 3 or Gen 4 models
See here
Hi. I got the following about a guy that instaled a front ARB diff lock to his NP.
See here
As i understand the RD110 from ARB fits most Pajero front diffs, is this correct
The PDF files specifies the ARB RD155 for the NM Pajero which is a Gen 3SimonB wrote:Megaworld are correct - there is no ARB Front Locker for Paj Gen 3 or Gen 4 models
See here
Look again - that's for the REAR locker4ePikanini wrote:The PDF files specifies the ARB RD155 for the NM Pajero which is a Gen 3
Ah. My mistake.SimonB wrote:Look again - that's for the REAR locker4ePikanini wrote:The PDF files specifies the ARB RD155 for the NM Pajero which is a Gen 3
I found the updated application chart as I knew ARB makes front lockers for the Gen 3/4
http://store.geo4wdparts.com/uploads/PD ... e_2010.pdf
Check pages 72 & 73
