ATF & Power Steering Fluid
Posted: Wed Jul 13, 2011 2:49 pm
by macjohnw
I bought some power steering fluid for my Gen3 3.2DID this morning. I pulled away from the garage and glanced at the bottle and saw it was ATF. So I turned back and asked them WTH this is. They informed me that ATF can be used for the power steering fluid also. :?:
Your thoughts on this?
Re: ATF & Power Steering Fluid
Posted: Wed Jul 13, 2011 3:33 pm
ATF and power steering fluid is almost identical. Power steering fluid is usually just thinner in viscosity.
You should be fine - just read the container - it may specify that it's OK in power steering systems.
Posted: Wed Jul 13, 2011 3:41 pm
by macjohnw
Sweet, thanks.
Posted: Wed Jul 13, 2011 3:56 pm
by bold4E
ATF is just a "fancy name" for a very high quality hydaulic oil. They are definately the correct ones to use for the power steering. My Gen 3 Owners Handbook spec either Dexron II or Dexron III for the power steering. It must at least read "xxxxx" III ATF.
Waldo Fourie
