I have managed to break/disconnect the cable attached to the handle n the side of the rear seat. This is the one use to slide it forward. To replace/repair this I need to remove the rear seat. Not having any luck. The advise posted on POCUK was to lower the back rest, get someone to jump on the folded seat while pulling up on the material straps on the bottom. This should "loosen" the bench to tip forward giving you access to the bolts that tie it down. No go , this thing is stuck. Any other suggestions?
