I have a off road caravan with a Inteelegent charging Unit in it with two 102 A/H Delco Voyager Batteries.
My question is:
Should you drain the batteries flat at some point in time
Secondly I do not know how this charging system works meaning is it a trickle charger and will the intellegent part first charge a single battery and then switch to the other battery or will it attempt to charge both at the same time
How long will it charge to complete both batteries
Someone suggested it should not take longer than six hours
My experience is that a deep cycle battery takes much longer to reach full capacity.
My batteries were flat , very flat and the charger has been running now for 48 hours non stop and the one battery does not show the green indicator as for good battery- it is still on the black circle meaning it still charging
Any suggestions or technical aspects will help.
