Piera
Gen 2 3.0 v6 Auto not going into 4th gear?
Hi people
This past weekend I have noticed that my car does not shift into 4th gear if I drive with the overdrive off and when I engage overdrive it will just briefly go into 4th but then shifts straight into 5th gear and when I want to shift down, it skips 4th and goes straight into 3rd again. Does anybody know if this is a major problem or what I could do to try and sort this problem out? I also posted in the electrical part of this forum about my 4H not showing on the dash indicator and thought it was the bulbs, but after changing the bulbs and reading about the super select 4wd Im not sure whether it does engage into 4wd or not, what happens is when it is in 2H the lights show that it is in 2wd, but when I shift into 4H, no other lights come on, but will sometimes after shifting a couple of times just flicker briefly, so how will I know if it is engaged or not?
Sorry for asking about two things, but I would really like to get some help on both matters.
Any help will be appreciated greatly!
Thanx
Piera
