Brake issue
I'he got a 2007 SWB 3.2 DiD and when braking its almost feels like the disks are uneven (the feeling is not like a shudder more like it grip and let got). The driver can feel it, but not the passengers. I friend said he had the same problem and it was resolved be replacing the booster pipe. Any useful opinions out there.
Brake issue
I had a similar issue on the rear disc on my Gen3. It turned out that the one slide pin on the caliper had siezed solid and the pads had worn down at a skew angle due to only one pin having movement on it. I stripped the brake and freed and re-greased the pin and replaced the pads. No problems since then.
Sent from my BlackBerry 9800 using Tapatalk
Nicholas Gibson
Corsa 1.4 Club (swambo)
Cape Town
