Sunroof Function on 2005 SWB
Posted: Wed Mar 06, 2013 7:49 am
by craigdre
Hi there
I am in desperate need of some assistance, my vehicle has been at a reputable company via the agents having the sunroof repaired for the umpteenth time and we are having a disagreement as to how the SR functions, ever since I have had the vehicle, the SR does the following: From closed, tilts up by holding the sunroof button in the middle, tilts down to close by pushing the button forward, opens SR by pulling button ONCE, SR then opens 95%, pull button once more and it open flush, i.e. 100%, now when closing from 95% only the glass closes, however when closing from 100% both glass and sunscreen close.
Please can someone confirm that the above is the correct functions with my car as the "reputable" company are disputing this, oh and they have managed to put a nice 10cm dent on the roof inform of the sunroof and are claiming it wasn’t them...
Looking forward to your comments
Craig
Re: Sunroof Function on 2005 SWB
Posted: Thu Mar 07, 2013 9:00 am
by craigdre
Anyone?
Posted: Thu Mar 07, 2013 12:11 pm
by Cas
Will check this evening and give some feedback. IIRC, it opens full,not 95%
Posted: Thu Mar 07, 2013 12:36 pm
by craigdre
I have made contact with another dealer in JHB and confimred that the above is the correct functioning for my sunroof
Posted: Thu Mar 07, 2013 2:36 pm
I'll also play with my sunroof tonight - if the rain goes away.
It does however now explain the odd occasion on which the inner cover "inexplicably" closed with the sunroof :D
Posted: Fri Mar 08, 2013 10:50 am
by martinbo
If you press the switch upwards, it tilts the sunroof. Pressing forward on the switch it will close, leaving the cover slightly open.
Press the switch backwards it opens the sunroof. Press it forward, the sunroof closes but leaves the cover behind.
Open the sunroof again, wait till it is fully open, press the button backwards again, it moves a little more to the back. Now close the sunroof and the cover will come along.
Posted: Fri Mar 08, 2013 11:07 am
Jip, that is the function on mine as well
Posted: Fri Mar 08, 2013 11:15 am
by craigdre
Thanks all
Fetching my car today after 3 weeks, fingers crossed, all is well
