I am new to the forum and hope someone can help me.
I drive a 2002 Pajero SWB DID 3.2, what a great vehicle!!!
I towed a trailer and now my right tail lights are not work, but the brake lights does and my dashboard light is not working.
I checked all the fuses ( at the engine and under the steering )
I replaced the clobes, but still no joy.
Jaco
Jaco,
I was waiting for someone else to answer this.
I know that you said that you have checked the fuses, but it is a common occurrence for the Pajero fuses to blow when towing. The OEM fuse rating does not cater for the additional load.
Look here Blown indicator fuse and warning lights and here Blinker fuse blown = Instrument warning lights! for example.
Jaco,
Sorry man - only saw this post now.
I agree with Andrew, it's a fuse. Double check, then re-check, then re-double check, but it will be a fuse.
Roelf
Roelf
Hi Jaco
double check those fuses. I have found that they look ok visually, but if tested, they are not.
