rear seats removal
Posted: Fri Jan 01, 2010 6:50 am
by colinken
Hi is it possible to remove the two seats at the very back of a pejero lwb 1997 model
Thanks Colin
Re: rear seats removal
Posted: Fri Jan 01, 2010 7:16 am
by Gerrit Loubser
Do you mean the jump seats that fold up against the sides of the load bay, Colin? If so, the answer is yes. It is quite easy to do. If I recall correctly there are some plastic trim pieces close to the hinge points that have to be removed and then you will see two largish bolts that hold each jump seat. Remove these and the seat is free. Those jump seats are not the lightest of things, though, so take a little care.
Posted: Fri Jan 01, 2010 12:20 pm
by SimonB
As gerrit said, all you need to do is remove the panel and undo the bolts. But you might just want to make sure the seats are already free from the floor where they hook in.
Posted: Sat Jan 02, 2010 6:08 am
by colinken
Thanks guys will have a go at it later today
