Uplift
Posted: Tue Jul 22, 2014 6:31 pm
by MVerster
I am planning a 2" lift or there about. I hear all kinds of advuce, but what will give the most satisfaction? OME seems to be the preference, but what about the others (iron man), EFS, or?
who did the work?
Re: Uplift
Posted: Tue Jul 22, 2014 6:51 pm
by andrew.ashton
@MVerster,
Consider the Stoffpad spacers - save you a heap and keep a smoother ride than upgraded springs.
Someone is offering a set of spacers at reduced cost in the For Sale section because their Paj does not fit in their garage with the spacers in.
If you then need to load level under heavy rear end loads, add Firestone air helpers from The Air Spring Supply Company.
If you plan to add a winch and other really heavy stuff upfront only then consider higher rated springs. Then consider OME, EFS or Tough Dog (not Iron Man - too many failure reports on shock bushes).
Re: Uplift - question?
Posted: Sun Dec 28, 2014 6:21 pm
by Tony
Did you lift your Pajero and did the 'spacers' work? I'm looking to do the same and need to find out what works and what doesn't.
