Good day,
I am new to this forum, and this is my first post. I recently switch from a 1994 LR Defender V8 station wagon (300k+ mileage) to a Blister 3500 V6 long wheel base (177k mileage). I must say the Landyonline forum was always a great help, and this forum seem similar.
Since I bought the Blister, I did the following :
Fixed a radiator leak, replaced the tie rod ends inner and outer, idler arm, front cv boots, skimmed all 4 brake disks, replaced brake pads and repacked the wheel bearings. Replaced the spotlights, did wheel alignment, fitted waterproof seat covers and spare wheel cover.
Now I want to replace the cracked rear bumper lights, and see if I can make the upper back lights work.
Can anybody here help me with new or decent 2nd hand rear bumper light fittings please.
I would also like advise on fitting small spotlights into the front bumper.
Thanks,
Gerhard
Hallo Gerhard.
I use the trailer light fittings ,(The round Ones)and make them fit into my rear lights ,If you have to buy them maybe it work out costly, but I have this in my stock and work perfect.
Front I use the small round spotlights, but you have to fabricate your own brackets.
I start this because I know some times the forum can be very quiet for new people.
It seems you are also a handy man.
Hope you get better advice.
