Jaco Naude
2000 3.5 V6 Gen 3 Intrument cluster intermittend
Hi, the instrument cluster on my Pajero is messing around a bit. Once vehicle is started nothing on instrument cluster work, No Speedo rev counter gauges nothing. Then after a while it starts working and every thing is back to normal. Once vehicle is turned of, it doesn't work again when started and after a while it comes back to life. Can anyone please help me as to what the problem could be? Thank you kindly Jaco Naude/
Re: 2000 3.5 V6 Gen 3 Intrument cluster intermittend
Jaco
Have a look at this video on Youtube. Might be part of your problem but as yours does not move at all I think it might be loose pickup sensor somwhere else and the cluster to be good?
How to fix a faulty temp gauge on a Pajero NM: http://youtu.be/JMI0_TezfwQ
Jaco Naude
CATS wrote:Jaco
Hi CATS
Thank you for your reply, I am not very clued up with these things. Can you by any chance give me an indication as to where these pick up sensors are located that I should check?
Thank you kindly
Jaco
