Hi Guys
Just want to share my experience having just fitted an after-market tow bar to my Gen 4 at a reputable 4x4 outlet.
I wont mention names as they did rectify the problem and I dont think this is their normal standard - but more a lesson to not assume things will be done properly and always check what has been done.
I took delivery and all looked good on the surface - a day later I then noticed a loose bolt on the bumper at the door sill. This made me look closer underneath to discover that one side of the tow bar appeared to be correct with 4 bolts to the chassis - the other however had one bolt missing and a second finger tight - ie only 50% of support on that side.
Had I not checked who knows what might have happened down the line.
Tim - Port Elizabeth
Typical.....
Sorry, but have had that experience with 2 different "reputable" 4x4 fitment ctrs..... Not only on my Colt and Paj, but also my Dads Cruiser.........
Bolts not fitted, incorrect spec bolts, bad wiring etc.... Unfortunately, you ALWAYS HAVE TO CHECK....
