jaco_n
Headlamp loose
The left headlamp is little bit loose on the bottom. There is some play and I have no idea where or how to fix this. I see there is a bolt on the top but nothing is moving. I have a gen 3, 2005 3,2 did. Can someone please show me what to look for and to fix it please?
thanks
Re: Headlamp loose
There is a nut that you need to get to behind the plastic inner wheel mudguard that holds the headlamp in place at the bottom. The headlamp has a stud there going through a hole and then you fasten with a nut. Nr 10 iirc. Check to see if yours is still there and tight.
