Traction control 'bug
Our 3.2 LWB Gen4 has developed a problem.
On a fast left hand bend (Fields Hill, for those that know the M13 out of Durban) the traction control light flashes and then the motor loses power until the car slows to about 75kph then everything returns to normal.
NB it only happens up hill, and only on left hand curves.
Any ideas as to what can be the cause of this issue?
Re: Traction control 'bug
Check for a faulty sensor on one of the wheels on front. My second thought would be is it not cause of the skid control and it removes power from engine as it thinks you going to spin a wheel?
I am not sure but that would be my first 2 checks.
Sent from my SM-N910H using Tapatalk
The TC might not be the cause, it must be the ASC. Next time, press the "ASC OFF" button in front of your left knee and see if it happens. Be careful though, it might cause a spin depending how fast you are going.
Dirty Boy
I get the same with my Gen 3, going up Fields Hill.
Check play on the wheel hubs. Had an intermittent ASC problem that was solved with replacing the worn (very) rear wheel hubs.
3200 Tdi GSL 2001 Written off
3500i A/T 5Dr 2001 Sold
3.2 Di-Dc GLS A/T 2008
Thinking basics first. We had an issue with a Mercedes Benz once. Turned out to be odd tyre size was causing one wheel to rotate faster than the others. Check tyre size, tyre pressure (maybe a combination of more than one factor) - I would think that tyre wear alone should be accommodated for. I have a new spare r/h rear at 10mm tread depth and l/r at 6mm tread depth and have not had a problem.
Points as mentioned by others above - anything to indicate different wheel speeds per wheel. The sensors I have found pretty reliable and if faulty should be held as a fault code in the vehicle system.
