GTO Motor in my 94 Gen2
Posted: Fri Mar 05, 2010 10:47 am
Hi All,
I am just letting you all know that I have started a transplant that I think will really make my Gen 1 SWB a menance to be dealt with.
(Moderator note:
For clarity, the heading was changed to Gen 2, since it has been established that the vehicle is in fact a Gen2 Pajero, not a Gen1.
The project would however be valuable to Gen1 owners, since the Gen1 and Gen2 engine bays are just about identical)
I originally started just wanting to swop out my manual gearbox for a Auto, nothing wrong with the Manual but just wanted auto and got a box from a 3500V6 Gen1. However when I started I was approached by another Gen1 LWB base owner here on Gaborone who had purchased a rebuilt GTO V6 24v DOHC motor (165kw, 238nm) and was going to fit it in his car. However he in the end did not have the energy to make it fit (apparently an issue with the throttle body that would interfere with the firewall and the computer re-wiring). So he asked me if I would consider swoping my 3.0V6 Gen1 Motor for the GTO motor so that he could get back on the road ASAP. Well for me it was a no brainer and the deal was done.
Its quite a simple swop, gearbox fits bolton, starter etc all the same. There is a small modification on the engine mountings (Bolt pattern on GTO Block) but easily sorted.On the throttle body problem, we are moving the Gearbox 10mm forward and should solve the problem, if not we are going to modify the intake manifold so that the throttle body sits at the front of the engine bay and block of the old throttle body mount at the back. this entails a little aluminium welding but also not too much of a problem. Follwong that all I will have to do it to mate the existing exhaust to the exh manifolds of the GTO Motor and do the ECU wiring and that should be it.
I am really exited about all this and will post pictures from now on.
Hope all you "adventures' are well and will let you know as progress is achieved.
P.S. Does anyone know of anyone has done this before or am I the 1st.
Steve
(Moderator note:
Steve
