Spot the difference
Posted: Sun Mar 07, 2010 10:51 am
before
after
Re: Spot the difference
Posted: Sun Mar 07, 2010 11:23 am
by KaiV
I see it..... At least they cant be bent any more.....
Posted: Mon Mar 08, 2010 1:18 pm
by KaiV
Am I the only one who spotted... even answered in a riddle....
Posted: Mon Mar 08, 2010 1:32 pm
hehe. Shadows moved as well.
Posted: Tue Mar 09, 2010 9:08 am
by KaiV
4ePikanini wrote:hehe. Shadows moved as well.
You shouldn't have mentioned that. Shows that it took you faaaaar too long to take em off
Posted: Tue Mar 09, 2010 9:15 am
KaiV wrote:4ePikanini wrote:hehe. Shadows moved as well.
I took the other side off first and they took much longer as you actually have to take the rails off and then the brackets.
I ended up loosening the brackets and then had to retighten (
loosening rusty bolts from a wobbly rail isn't fun )them to get the rails off.
So when I did the second set I knew the procedure and it took me about 10 minutes, as opposed to 30 for the first set.
Posted: Tue Mar 09, 2010 1:46 pm
by KaiV
Cutting torch works on any rusted and or stripped bolt
Posted: Tue Mar 09, 2010 1:49 pm
KaiV wrote:Cutting torch works on any rusted and or stripped bolt
I haven't got a cutting torch. Just some penetrating oil spray. Never had a problem yet.
Posted: Thu Mar 18, 2010 1:04 pm
by ThePajeroMan
4e give us some more detail on the sliders/steps.
Posted: Thu Mar 18, 2010 1:51 pm
ThePajeroMan wrote:4e give us some more detail on the sliders/steps.
The bolt on to the chassis with 3 bracket on each side. Each bracket has 2 bolts to bolt to the chassis and 2 bolts to bolt to the rails. Yes it's a lot of bolts
Brackets are high strength steel and the rails are aluminum.
Do you want them? I doubt I'll ever put them back - maybe rock sliders some time.
Make me an offer.
