charl123
LEAK FROM ROOF RAIL
GOOD DAY ALL
I HAVE NOTICED WATER LEAKING INTO VEHICLE BY THE TOP PANIC HANDLE ON THE LEFT SIDE OF THE CAR AND SUSPECT ITS COMING THRU VIA ROOF RAIL? ANYBODY ELSE HAD THIS PROBLEM AND DOES ANYONE KNOW IF I CAN TAKE THAT RAIL OF TO TRY AND SEE WHAT THE PROBLEM IS?
THANK YOU
CHARL
vaughn
Re: LEAK FROM ROOF RAIL
Hello,
Check your windscreen it might be leaking,I had a similar issue with my vehicle after the screen was replaced, the water runs in the roof lining or along the plastic trim. Good luck.
