2008 Pajero LWB 3.2l DiD Cracked Rim
Posted: Thu Jan 11, 2018 4:43 pm
When I purchased my second hand Pajero just over a year ago one of the first things that I had done was wheel alignment and balancing. During wheel balancing they found one wheel rim was damaged but wanted an exorbitant fee to have it fixed so I had them swap the rim for the spare tyre's one.
Fast forward I recently had my tyres rotated and rebalanced at a different facility which also quoted me a more realistic figure for the repair of the rim. When I went to pick up the rim the company told me that the rim could not be repaired because there was a hairline crack from one side to the other. To top it all, someone at some stage had tried to repair the rim using metallised epoxy cement.
Any idea how one can manage to damage a wheel rim so badly?
As I mentioned, the damaged wheel was in use on the car for a few weeks before the problem was found. Apart from some possible steering vibration there didn't seem to be anything wrong with it (no loss of pressure that I remember - and certainly no loss as the spare). So it's back on the Paj as a spare but I'm contemplating finding a replacement. However at R11,180 excl VAT from Mitsubishi
perhaps a second hand one might suffice - although buying from a breaker's yard one is not guaranteed to get one that is in good conditions/without problems. The Paj's Suspension seems fine also although there is sometimes a slight 'knock' when turning to the left (agent's say it's to do with a worn steering coupling bolt/hole in the steering 'collapsing mechanism' should a front end collision take place.)
I should hasten to add that the vehicle was purchased for long distance travel and/or use on dirt/gravel roads or sand - not 'rock climbing'.
Any advice would be appreciated.
TIA
TIA
