3.2DID flywheel
Posted: Thu Apr 08, 2010 4:34 pm
by kawasaki
Hi everybody
I am looking for a flywheel for my 3.2did 2001 model.Does anybody have 1?
Re: 3.2DID flywheel
Posted: Fri May 21, 2010 9:41 am
by Fielies
Hello,
My mate just replaced his flywheel on his 3.2DID and cost him a fortune (R25000) I doubt it that you'll find a separate flywheel as they told him that the clutch plate has to be replaced with the flywheel.
Just do some home work on this.
Re: 3.2DID flywheel
Posted: Fri May 21, 2010 9:59 am
you can use the flywheel and clutch from a 2.8
Re: 3.2DID flywheel
Posted: Fri May 21, 2010 10:37 am
Dual mass flywheel is a "nice-to-have".
My Di-D has the 1-piece flywheel and clutch assembly from the 2,8 TD.
It is as smooth as anything.
Bolts straight on. make sure about the size of the ring gear, though (otherwise the starter won't match).
There are different mounting plates (between engine and bell-housing) for the different configurations.
Martin at PartHunt in Pretoria should have what you are looking for.
