Hi guys does anyone have the manual to set up the Mitsubishi radio in the 2005 model or can give me the steps to follow. Firstly the radio does not switch on with the ignition, have to press the on button and then press the station button. Secondly the CT setting to switch the automatic time setting off can be done but when you switch off and leave for a while it looses that setting and has to be re set again when switching on again. Is this normal or is there a way to set it up that the radio comes on with the ignition, all help will be appreciated as I do not have a owners manual and cant seem to find one to download...
