Electric Vacuum Pump
I saw a youtube video about a guy installing an electric vacuum pump on his diesel vehicle. Is this a viable option for the Pajero? I see my vacuum pump doesn't really supply a whole lot of vacuum, maybe that is why my brakes are so hard and my super select is giving hassles? Where can one source such a pump from?
Re: Electric Vacuum Pump
I might have the same problem with my 2004 LWB
I have now done the following so far, but without success as yet
1. Bled the brakes all around
2. Swapped the two relays that are mounted near the booster unit, still no change
3. had the vehicle by Mercedes/Mitsubishi workshop, and checked on their computer for any fault codes, nothing
4. Had vehicle at another workshop, checked with their computer, no vaults. What they did though, was to initiate the brakes and ABS to all 4 wheels separately, and we found the unit to run almost double the time (that pump running), to the left front and rear wheel
Where are we now at
We will check the vehicle again, this time drive it with the computer running as we drive and brake, and hopefully get answers
The pump would cycle at least once every 10 seconds, even with only the ignition on,
I contacted the Mitsubishi parts store in PTA, and they quoted R10 000 for the unit
Good luck, and please let us know should you find the cause
