Automatic Gen 3 DID 3.2 cruise control not coming on
My cruise control does not go on at all- checked the brake lights etc and its fine, it should go on at the dash regardless , when Arnold plugged in the diagnostics machine he said its not even communicating or picking up any cruise control to begin with on my car. Also mentioned that its not my clock spring.
My questions:
1. Does anyone have a electrical diagram showing the CC wiring and where it gets power etc?
2. Where does the CC get its speed reading for, I believe there is a electronic box where the CC electrics are located, where is it situated?
3. Where does the CC get its power from?
4. Which one is the lightbulb for the CC at the back of the dash? Perhaps its burnt out?
Re: Automatic Gen 3 DID 3.2 cruise control not coming on
I woukd start with the clock spring regardless. Its a known failure point.
Make sure your brake switch is the 4pin, not the 2 pin.
Sent from my SM-A505F using Tapatalk
