Overfilled autobox
- Dirty Dog
- Country: South Africa
- Vehicle: 2007 Pajero DiD LWB
Post
Overfilled autobox
I have the Gen4 DiD, and I sometimes get a lag when you start accelerating. I have now discovered that the auto-box fluid is way over the mark. Can this be the cause, and what else could it result in? I do find that the consumption is a bit high - my son's 3.8 Gen4 is lighter on fuel!
- Roelf_le_Roux
- Contact:
Post
Re: Overfilled autobox
1) A DiD that is heavier on fuel than a 3.8V6 doesn't sound right.
2) Did you check the gearbox oil level as per instructions in the owner's manual?
Sent from my SM-N970F using Tapatalk
- 4ePikanini
- Affiliate Member
- Contact:
Post
Autobox level should be checked while car is parked, idling and on level ground.
- NeelsLaubscher
- Vehicle: Pajero 3.2 DiD SWB AT 2008
Post
Hi everybody. I have a 2008 PJ swb 3.2
Also questions. What would be the symptoms/results of an overfilled box, how do you drain if oil level is to high, would it cause any damage on the long term?
