Fault codes
Posted: Mon Jan 03, 2011 11:43 pm
by Mickster
Hi all,
Just wondering where i could find a list of fault codes and a few lines on what each mean? any ideas?
Mine threw up:
43
51
52
31
Tks Mickster
Re: Fault codes
Posted: Thu Jan 06, 2011 6:49 pm
by Mickster
Here are a couple more historical one too!! Am I in trouble??
Or how deep?
18
43
25
31
52
51
Tks Mick
Re: Fault codes
Posted: Tue Jan 11, 2011 3:44 pm
by pierreandre
Check this page. It has a very comprehensive listing.
http://www.evoscan.com/technical-vehicl ... iagnostics
Is your engine warning light on? If not, the errors are probably transient. How did you read the error codes?
Re: Fault codes
Posted: Thu Jan 13, 2011 12:29 pm
by calvinc
i had my 3.2 Di D on the machine yesterday, this is what they found and explained to me:
43- Injection firing solenoid valve
52- Boost pressure control valve faulty
51= EGR - Exhaust position sensor open on short circuit (they blocked it off)
thats all i can assist you with
Re: Fault codes
Posted: Fri Jan 14, 2011 9:40 am
by Mickster
Hi Guys,
Thanks for the replies! Will check out the site.
Calvin, my engine light comes on sometimes. But my Paj is running terrible. The codes were read at midrand turbo and diesel. due to code 43 they said my Injector / fuel pump had gone and needed a recon one at R23k... hence me wanting to investigate further!!
Was your Paj running badly? and what did your mechanics advise re your fault codes?
Many tks! Mickster
Re: Fault codes
Posted: Mon Nov 28, 2011 8:42 am
by Shaun
I have a pajero GLX lxb 2005 3.2 DID
I have The following errors and need help desperatley to fix
My error codes are
43 41 31 52 51
after reseting them
The new errors are
31 CAN COMM.
52 VGT CONT.PRS.
51 EGR POS. SNSR
I have had the EGR valve blocked , and engine light comes on from time to time??
please can you advise me on how/what to do ??
Shaun
Re: Fault codes
Posted: Mon Nov 28, 2011 10:42 am
by JohanV
Interesting that some how allot of people have the same error codes
I am still trying to solve my as well
https://www.pajeroclub.co.za/forum/view ... =24&t=3191
someone mentioned a solenoid that might needs replacement to me over the weekend.
Re: Fault codes
Posted: Mon Jun 10, 2013 9:27 am
by llec999
Did we find a solution to error codes, 31, 51, 52? I have the same problems. It is accompanied by a lot of white smoke from time to time and also a diesel knock. I don't know what is related and what not as this Pajero was bought as a non-runner. (3.2 Did)
Any stories on what happened to your codes will be helpful...
(And by the way my EGR is also blanked of - and that would explain 51 but not the smoke or disel knock - am I correct?)
Re: Fault codes
Posted: Wed Jun 12, 2013 3:54 pm
by gaaloul.med
Good day everybody,
since I am a network manager at a Mitsubishi distributor in Tunisia. I can help you a little bit by the attached diagnosis codes data sheet, for 4M41 engine 2000 - 2001, extracted from the workshop manual but unfortunately they are in French seen that this last one is our second official language. So, you can translate the needed code explanation
sorry.
At your disposal for any further information.
With regards,
Re: Fault codes
Posted: Wed Jun 12, 2013 4:01 pm
by gaaloul.med
Second part for Pajero 3.2 DI-D 2002 - 2006.
